Single/double press detection from www.logicmachine - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Single/double press detection from www.logicmachine (/showthread.php?tid=5355) |
Single/double press detection from www.logicmachine - Borek - 11.04.2024 Hello everyone, I used the script from www LogicMachine/Documentation and examples - Single/double press detection. I followed the instructions and the script did not work. After restarting LogicMachine it worked, but after editing it stopped working and restarting LogicMachine didn't help either. Has anyone encountered something similar or any ideas? Thanks Borek RE: Single/double press detection from www.logicmachine - admin - 11.04.2024 Check that the resident script sleep time is set to 0. RE: Single/double press detection from www.logicmachine - Borek - 11.04.2024 (11.04.2024, 10:44)admin Wrote: Check that the resident script sleep time is set to 0. Yes, I have... RE: Single/double press detection from www.logicmachine - admin - 11.04.2024 Post your script. What exactly have you changed? RE: Single/double press detection from www.logicmachine - Borek - 11.04.2024 (11.04.2024, 14:45)admin Wrote: Post your script. What exactly have you changed? -- maximum time between presses presstimeout = 0.5 mapping = { ['9/0/0'] = { -- single press single_address = '9/1/0', single_value = FALSE, -- double press double_address = '9/2/0', double_value = TRUE, -- multi (3+) press (optional) multi_address = '9/0/9', multi_value = 33, }, ['9/0/1'] = { -- single press single_address = '1/3/40', single_value = TRUE, -- double press double_address = '1/3/41', double_value = TRUE, }, } require('copas') function write(map, key) local address = map[ key .. '_address'] local value = map[ key .. '_value'] if address and value ~= nil then grp.write(address, value) return true end end function timerthread(addr, map) local counter = 0 local timeout = -1 -- suspend thread while true do copas.sleep(timeout) if map.counter == counter then if timeout == presstimeout then if counter == 1 then write(map, 'single') elseif counter == 2 or not write(map, 'multi') then write(map, 'double') end timeout = -1 counter = 0 map.counter = 0 end else timeout = presstimeout counter = map.counter end end end for addr, map in pairs(mapping) do map.counter = 0 map.thread = copas.addthread(timerthread, addr, map) end function eventhandler(event) local map = mapping[ event.dst ] if map then map.counter = map.counter + 1 copas.wakeup(map.thread) end end lb = require('localbus').new(1) lb ethandler('groupwrite', eventhandler)copas.addserver(lb.sock, function() lb.sock = copas.wrap(lb.sock) while true do lb tep()end end, 1) copas.loop() ONLY: adress and value... RE: Single/double press detection from www.logicmachine - admin - 11.04.2024 true/false must be in lowercase RE: Single/double press detection from www.logicmachine - Borek - 11.04.2024 (11.04.2024, 15:10)admin Wrote: true/false must be in lowercase Thank you very much, I forget that LUA has to be lowercase..... ((
