ZeroTier network management - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: ZeroTier network management (/showthread.php?tid=5360) |
ZeroTier network management - alb-smith - 13.04.2024 We use LMs configured on different ZeroTier networks. If you change any parameter (e.g. remove a ZT network, rename it or add a new ZT network) the LM becomes unreachable with ZeroTier and a local reboot is required. We tried to reboot remotely but after confirming the changes to the ZeroTier service it is no longer possible to send commands and the connection with the device is permanently lost. We also use multiple ZT networks to ensure a backup connection but this does not seem possible. Thanks RE: ZeroTier network management - admin - 15.04.2024 Tested with latest firmware - adding or removing a network while connected via ZeroTier works normally. It might take some seconds for the device to reconnect due to the ZeroTier service restart. RE: ZeroTier network management - alb-smith - 15.04.2024 (15.04.2024, 09:04)admin Wrote: Tested with latest firmware - adding or removing a network while connected via ZeroTier works normally. It might take some seconds for the device to reconnect due to the ZeroTier service restart. Very good! Let's wait for the final version of the new FW. We try not to install release candidates versions on production machines. Thank you. |
