[OLD] LogicMachine firmware 2024.04 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: Announcements (https://forum.logicmachine.net/forumdisplay.php?fid=7) +--- Forum: Software updates (https://forum.logicmachine.net/forumdisplay.php?fid=13) +--- Thread: [OLD] LogicMachine firmware 2024.04 (/showthread.php?tid=5363) |
[OLD] LogicMachine firmware 2024.04 - admin - 16.04.2024 2024.04 RC3 https://forum.logicmachine.net/showthread.php?tid=5393 Changes from 2024.02 RC1 - Fixed BACnet client direct connection mode - Fixed redirect from login missing URL parameters when multiple parameters are used - Fixed missing password match validation in the main configurator Known issues - Homekit application must be updated to the latest version via LM app store after the firmware upgrade. New LM Home application More info here: https://forum.logicmachine.net/showthread.php?tid=5220 You can find the hardware model in the "Upgrade firmware" window: LM5 Power devices with i.MX6 CPU LM5 Lite (3 DIN units): image file | signature LM5 Lite + Ext (4 or 6 DIN units): image file | signature LM5 Reactor GM KNX: image file | signature LM5 Reactor GM CANx: image file | signature LM5 Reactor Dimmer KNX: image file | signature LM5 Reactor Dimmer CANx: image file | signature LM5 Reactor IO V2/V3: image file | signature LM5 Reactor IO V2/V3 + LTE: image file | signature LM5 M4 (4 DIN units): image file | signature LM Wall (Ambient V2): image file | signature Extra packages (i.MX6 CPU) libmysqlclient has been replaced by libmariadb. No script changes are needed for MySQL/MariaDB connectivity. KNX Data Secure Video tutorial: https://forum.logicmachine.net/showthread.php?tid=5243&pid=33915#pid33915 RE: [RC2] LogicMachine firmware 2024.04 - kike - 25.04.2024 Hi, I have just noticed that something change in this version, usually when I want to create an object is: grp.create({ datatype = 7, address = '10/1/16', name = 'Dato16', units = ' d16', tags = { 'Tipo16' }, }) But in this version this error pops up and nothing is done maybe change the database structure? Thanks!! RE: [RC2] LogicMachine firmware 2024.04 - admin - 25.04.2024 Try adding require('json') before calling grp.create() as a work-around. This will be fixed in the next version. RE: [RC2] LogicMachine firmware 2024.04 - Fahd - 26.04.2024 Hi, I still have ZeroTier config error RE: [OLD] LogicMachine firmware 2024.04 - admin - 30.04.2024 @Fahd, please try RC3: https://forum.logicmachine.net/showthread.php?tid=5393 |
