Google Home Device and Trait - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Google Home Device and Trait (/showthread.php?tid=5364) |
Google Home Device and Trait - savaskorkmaz - 16.04.2024 Hi, I have a problem with the usage of Trait in Google Home Application. I created a 'Water Heater' Device which comes with only On-Off action. I added Temperature Control Trait. I added all the group addresses in both on-off and temperature control traits. When i add to Google home and when i open the Google Home app, i see only OnOff function in the Google Home . I can't see any additional control function for added traits. LM Firmware : 202404 Google Smart Home VersionĀ is : 2021 RE: Google Home Device and Trait - Daniel - 16.04.2024 Google does not provide graphical interface for all. The voice control still should work but do not expect nice graphics on google home for everything. RE: Google Home Device and Trait - savaskorkmaz - 16.04.2024 Hi, I don't expect good graphics. But you know, there are simple buttons in google home application. I say, there is only one function in this button for graphical and voice control. I'cant control from google Home the second trait in the heater ( Temperature Control trait ) with google home simple button nor Google Assistant Voice control. Can you make a example try this please ? Create a water heater device . Add Temperature Control trait to this device. and try to control via google home button or Google Home Assistant. I failed to control second added trait RE: Google Home Device and Trait - Daniel - 17.04.2024 I did and it works. You can say to the assistant: Set 'water heater' to 25 degrees, as well as turn on/off 'water heater' How did you configure the triat? |
