Get group address from event script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Get group address from event script (/showthread.php?tid=537) |
Get group address from event script - baggins - 04.01.2017 Hi, Is it possible to obtain the group adress of an object from which an event script was triggered? I have a number of objects that have the same tag and an event script triggered by the tag. When the scripts executes, I now check each object with an if ... elseif until I find the object. It would be more elegant and possibly quicker if I could determine the object directly. Thanks. RE: Get group address from event script - Erwin van der Zwart - 04.01.2017 Hi, Use event.dst BR, Erwin RE: Get group address from event script - baggins - 04.01.2017 (04.01.2017, 13:03)Erwin van der Zwart Wrote: Hi, Hello Erwin, Is this documented somewhere? I looked at the documentation mentioned in the first post of this section but could not find it... Thx EDIT: OK, this was a case of just RTFM...
