Reactor modem problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Reactor modem problem (/showthread.php?tid=5371) |
Reactor modem problem - Frank68 - 19.04.2024 HI I have a problem with the LM5 Reactor GM KNX, already updated to the latest firmware version, it doesn't get the IP from the cellular network, I tried the SIM on a phone and the card works, as usual no GW configured. What could it depend on? A thousand thanks RE: Reactor modem problem - admin - 19.04.2024 1. Check that the modem is detected when the system starts in System config > Status > System log. 2. Run this script and post what you get in Logs: Code: tty1 = '/dev/ttyACM3'
tty2 = '/dev/ttyUSB2'
if io.exists(tty1) then
tty = tty1
elseif io.exists(tty2) then
tty = tty2
log('port not found')
return
port = require('serial').open(tty)
if not port then
log('cannot open port')
return
function readstatus()
local data, res, simok, network
port:flush()
port:write('AT+CSQ\r\n')
data = port:read(1000, 1)
if data then
res = data:match('+CSQ: (%d+)')
res = tonumber(res)
if res then
log('Signal: ' .. tostring(res))
log('Signal: no response')
log('Signal: no data from port')
port:flush()
port:write('AT+CPIN?\r\n')
data = port:read(1000, 1) or ''
if data:find('CME ERROR') then
log('SIM: not found')
elseif data:find('+CPIN: READY') then
log('SIM: OK')
simok = true
log('SIM: unknown')
port:flush()
port:write('AT+COPS?\r\n')
if data then
res = data:match('+COPS: %d+,%d+,"(.*)",%d+')
if res then
log('Network: ' .. tostring(res))
network = res
log('Network: no info')
log('Network: no data from port')
return simok and network
for i = 1, 20 do
if readstatus() then
break
endRE: Reactor modem problem - Frank68 - 19.04.2024 (19.04.2024, 07:55)admin Wrote: 1. Check that the modem is detected when the system starts in System config > Status > System log. OK in the log i see error network no info and SIM not found signal 13, but in the phone the SIM works. Why ? RE: Reactor modem problem - admin - 19.04.2024 Maybe it's a hardware fault. Is it a new device or an older one that worked before? RE: Reactor modem problem - Frank68 - 19.04.2024 (19.04.2024, 08:17)admin Wrote: Maybe it's a hardware fault. Is it a new device or an older one that worked before? Is a device that we had at home never used and that we sent to you to install the LTE modem instead of the GSM and now I had to use it on a system. now IP is released, SMS also work from mobile but Zerotier doesn't see it when I use the integrated MODEM. when i try to see if Zerotier get IP have this message RE: Reactor modem problem - BMSimon - 14.02.2025 Same problem here, we are connected over ZeroTier the LM is with LTE and we are not able to change the ZeroTier network ID. If we click on ZeroTier we get the same error as above. Any solution to this? RE: Reactor modem problem - admin - 14.02.2025 Try temporarily setting gateway and DNS in Network > Interfaces > eth0. RE: Reactor modem problem - BMSimon - 14.02.2025 (14.02.2025, 08:32)admin Wrote: Try temporarily setting gateway and DNS in Network > Interfaces > eth0. ![]() Change it to what? RE: Reactor modem problem - admin - 14.02.2025 Temporarily change Protocol to Static and provide gateway and DNS. Save but don't reboot LM. After changing ZeroTier settings switch back to DHCP. This issue will be fixed in the next firmware. |
