Status of zones and subzones - Printable Version
+--- Thread: Status of zones and subzones (/showthread.php?tid=5375)
Status of zones and subzones - mai - 22.04.2024
I want to indicate the status of Zones and subzones.
For example, if I have zone A, which is made up of zones 1, 2 and 3.
I have three general on/off buttons: for the entire zone A, and independently for each zone 1,2,3.
I want that if any of the subzones is activated, I want zone A to also be activated. I want the zone's general on button to be held down both in the subzone and in the zone.
Using the script, how could I do it?
RE: Status of zones and subzones - Daniel - 22.04.2024
Use or gate
https://kb.logicmachine.net/scripting/logic-functions-central-statuses/
RE: Status of zones and subzones - mai - 24.04.2024
(22.04.2024, 07:22)Daniel Wrote: Use or gate
I have created an event script that is triggered by a tag.
What I want to do is that if any of the group addresses that have the label are ON, the status address 3/0/100 is set to ON.
If all addresses are OFF, let address 3/0/100 be set to OFF.
   if 'tag' == true then
       grp.write('3/0/100', true)
      grp.write('3/0/100', false)
but when I command an ON from any of the objects that have the label, the address 3/0/100 is always updated with an OFF
RE: Status of zones and subzones - Daniel - 24.04.2024
Please use the example I sent you. There are examples for event script for this solution on the forum if you really need event, use search.
