Secure Communication for GRMS - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Secure Communication for GRMS (/showthread.php?tid=5376) |
Secure Communication for GRMS - darklord - 22.04.2024 I've already opened a thread about secure communication for modbus. As I understand it, it's not possibleĀ for the Logic Machine now. Secure Modbus Implementation (logicmachine.net) Do you have any suggestions for other protocols compatible with Logic Machines and easy to integrate with KNX, similar to Modbus? It must be secure by default. I'm exploring the best option for GRMS industry. Your advice is much appreciated. RE: Secure Communication for GRMS - Daniel - 22.04.2024 What are you trying to integrate? If you want secure communication the MQTT would be best. RE: Secure Communication for GRMS - darklord - 22.04.2024 (22.04.2024, 09:00)Daniel Wrote: What are you trying to integrate? If you want secure communication the MQTT would be best. I need to poll occupancy status, temperature information, and room status information every 2-3 seconds. I should also be able to set room settings (light, temperature, blinds etc.) from the Logic machine instantly. Modbus is easy to implement with registers. MQTT, on the other hand, seems a bit complex to implement. Is BACnet feasible? RE: Secure Communication for GRMS - Daniel - 22.04.2024 Bacnet is same as modbus. Why don't you use KNX data secure? We are planning to make BACnet SC but this would be for server and can't tell when it will be available. RE: Secure Communication for GRMS - admin - 22.04.2024 Another option is to use HTTP: https://kb.logicmachine.net/misc/remote/#examples But as Daniel said, MQTT is the best approach because it does not require constant polling. For BACnet secure you also need another device that acts as a communication hub, we don't plan to support direct connection option in BACnet secure. |
