Bacnet Client SpaceLynk Script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Bacnet Client SpaceLynk Script (/showthread.php?tid=5411) |
Bacnet Client SpaceLynk Script - equalizer - 08.05.2024 require('bacnet') device, objects = bacnet.scandevice(ID) Fails with "Module 'bacnet' not found." Has the package for Bacnet Client via script been added to SpaceLynk and just called something else? Robert. RE: Bacnet Client SpaceLynk Script - admin - 08.05.2024 This is only available in LM. RE: Bacnet Client SpaceLynk Script - equalizer - 08.05.2024 (08.05.2024, 15:58)admin Wrote: This is only available in LM. Oh no. :-( Is the "App" really limited to bacnet 50 points? Robert. RE: Bacnet Client SpaceLynk Script - Daniel - 08.05.2024 It is not limited to 50 but you will not get much more out from it. RE: Bacnet Client SpaceLynk Script - AEK - 08.05.2024 (08.05.2024, 16:23)equalizer Wrote:(08.05.2024, 15:58)admin Wrote: This is only available in LM. I use it with around 500 variables since 2020 - works correct, but: when you start mapping from zero it works perfect, when amount of knx objects are growing - the app beacome very slow. scan 1 bacnet device with 300 variables - y must wait for a minute. Or maybe 10 minutes)) every time it is different. add new object mapping - once again wait 1-10 minutes and then - sometimes nothing, and you should wait again)) but communication is correct. knx objects go to bacnet at the same moment. feegback from bacnet to lm could go about 1-2 minutes RE: Bacnet Client SpaceLynk Script - equalizer - 14.05.2024 (08.05.2024, 18:01)AEK Wrote: I use it with around 500 variables since 2020 - works correct, but: Yep, now I have tried it on a real device its super slow beyond 50 points. RE: Bacnet Client SpaceLynk Script - Alberto.ricof - 15.05.2024 (08.05.2024, 15:58)admin Wrote: This is only available in LM. Good morning, I have a LM version 20240306 where can I download the module to use LUA with Bacnet ? By default, when I try to use it, I get the following message: ‘Resident script:1: module “bacnet” not found...’. Thanks in advance, RE: Bacnet Client SpaceLynk Script - Daniel - 15.05.2024 https://dl.openrb.com/lm-24-imx6/pkg/ RE: Bacnet Client SpaceLynk Script - Alberto.ricof - 15.05.2024 (15.05.2024, 10:59)Daniel Wrote: https://dl.openrb.com/lm-24-imx6/pkg/ Thx !! (15.05.2024, 10:59)Daniel Wrote: https://dl.openrb.com/lm-24-imx6/pkg/Hello again, To install this bacnet package (it's the first time I do it), I understand that you have to do it from the Apps section, right? Apps->install from file... You have to do or enable something else? when uploading the files I get an error in the signature file. If I upload it omitting the signature file, it also gives error. Maybe there is a problem with that file...? Greetings, RE: Bacnet Client SpaceLynk Script - Daniel - 15.05.2024 This is not an app ![]() Go to System config - System - Packages. |
