Connect multiple IP routers at the same time on LM5 ! - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Connect multiple IP routers at the same time on LM5 ! (/showthread.php?tid=5417) |
Connect multiple IP routers at the same time on LM5 ! - phongvucba - 16.05.2024 Hi everybody ! I have a project that does not use knx line coupler. I have used many IP routers, here is Jung's IPR300. And I want LM to connect to all those router IPs. Can LM? Each floor has 1 IP router device, so I want to use LM to program the whole building. The internet is the same IP range. Thank you very much everyone! RE: Connect multiple IP routers at the same time on LM5 ! - Daniel - 16.05.2024 Yes but only on 2024 fw. RE: Connect multiple IP routers at the same time on LM5 ! - phongvucba - 16.05.2024 Thank Daniel! So 2025 fw will have this update? RE: Connect multiple IP routers at the same time on LM5 ! - Daniel - 16.05.2024 2024 already has it. RE: Connect multiple IP routers at the same time on LM5 ! - alexll - 16.05.2024 (16.05.2024, 10:05)Daniel Wrote: 2024 already has it. Hi Daniel. Mind you tell us how to do this? I can't find where to put the different connections. Thanks! RE: Connect multiple IP routers at the same time on LM5 ! - Daniel - 16.05.2024 You just enable this: Pass ind. telegrams via IP Routing RE: Connect multiple IP routers at the same time on LM5 ! - phongvucba - 17.05.2024 (16.05.2024, 12:27)Daniel Wrote: You just enable this: Pass ind. telegrams via IP Routing oh, thank so much ! But I don't quite understand, where can I fill in another Multicast? or other router IP, other than 224.0.23.12
RE: Connect multiple IP routers at the same time on LM5 ! - Daniel - 17.05.2024 This works as any other KNX IP router, multicast must be the same on all. RE: Connect multiple IP routers at the same time on LM5 ! - phongvucba - 17.05.2024 Thank Daniel ! oh, that means I have to configure all my IProuter devices to have a Multicast of 224.0.23.12, which is the same
