from watt to kilowatt - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: from watt to kilowatt (/showthread.php?tid=5422) |
from watt to kilowatt - mai - 20.05.2024 I have done this scritp to change the value from watt/h to kilowatt/h. But it gives me always 0. Why?? ------------------------------------------------------------------------------- function kilowatt() local value = event.getvalue('32/2/16') if value then local new_value = value * 0.001 return new_value else end end local valor = kilowatt() grp.write('32/2/16', valor) RE: from watt to kilowatt - admin - 20.05.2024 You need to use a different object/group address to store the kW value. Otherwise your script is an infinite loop which will overload LM. Simplified version of this script (32/2/17 must not be the triggering object): Code: kw = event.getvalue() / 1000 |
