roll down shutter when theres an alarm - Printable Version
+--- Thread: roll down shutter when theres an alarm (/showthread.php?tid=5424)
roll down shutter when theres an alarm - h5345 - 20.05.2024
hi, im trying to use a script to roll down a shutter when theres an alarm
alarm1 = grp.getvalue('0/0/x')
-- i dont know if im getting the shutter position right by getting the value from "movement in manual mode" object, 1.008
shutterposition = grp.getvalue('0/0/y')
if alarm1 then
if not shutterposition then
grp.write('0/0/x/', true)
i did try the script out and it was working but they told me today its not working. if the shutters half open, should the script still work?
there was also another object for height feedback (5.001 0-100%) but it wasnt getting updated for one of the shutter so i tried using the other object and im guessing its not getting updated correctly
should i be using 'feedback for last direction' object in the if statement?
edit: nvm, they told me its working. the script runs every 2 minutes and they didnt wait that time. i should probably switch it to event based
RE: roll down shutter when theres an alarm - admin - 21.05.2024
Do you really need to check the current shutter position? The shutter controller should have end detection sensors so if it's already in down position then simply nothing will happen.
RE: roll down shutter when theres an alarm - h5345 - 21.05.2024
(21.05.2024, 07:28)admin Wrote: Do you really need to check the current shutter position? The shutter controller should have end detection sensors so if it's already in down position then simply nothing will happen.
for some reason i kept hearing the knx shutter modules relays changing their position
RE: roll down shutter when theres an alarm - h5345 - 22.05.2024
is this the right way to make the comparison in the if stament
if x <= 99 then
where x is the height feedback for the shutter(5.001 data type 0-100%)?
RE: roll down shutter when theres an alarm - Daniel - 23.05.2024
Yes, post your full script if you want us to check it. You can use script helper, there is also Code shortcut(top right corner) if you not sure how some code should be typed.
