Plan background image change - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Plan background image change (/showthread.php?tid=5429) |
Plan background image change - jmir - 23.05.2024 Hi, Is it possible to change "Primary background image" in a plan depending on object value? Or hidding showing primary or secondary background image? I've seen something here https://forum.logicmachine.net/showthrea...05#pid2205 but if it's possible to do it changing background image it should be better... Thanks! RE: Plan background image change - admin - 23.05.2024 You can change the background like this: Code: $('.plan-background').css('background-image', 'url(link_to_image)')RE: Plan background image change - jmir - 24.05.2024 (23.05.2024, 09:00)admin Wrote: You can change the background like this: Ok thanks! |
