Zerotier stange message - Printable Version
+--- Thread: Zerotier stange message (/showthread.php?tid=5441)
Zerotier stange message - Frank68 - 29.05.2024
Greetings
I was trying to understand a configuration problem on a REACTOR LTE, I'm configuring it for a system, as long as I configure the correct GW present on site everything is ok Zerotier works and the text messages arrive, when I configure the parameters of the customer's network Zerotier gives me a message that wants a GW and a DNS, the NDS uses 8.8.8.8 and the GW is not reachable at the moment, the LTE signal is present and the IP can be modified OK but I'm not reluctant to connect via TLE even if Zerotier tells me it's online ???
What can it be
Thank you
RE: Zerotier stange message - admin - 29.05.2024
https://forum.logicmachine.net/showthread.php?tid=5436&pid=35127#pid35127
