log KNX TP load - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: log KNX TP load (/showthread.php?tid=5452) |
log KNX TP load - Hadeel - 05.06.2024 Hi! Is there a way to get the value of KNX TP load from KNX statistics? I tried to find if there is such function but I could not find one... Thank you for your advice in advance! RE: log KNX TP load - admin - 05.06.2024 https://forum.logicmachine.net/showthread.php?tid=2552&pid=16316#pid16316 RE: log KNX TP load - Hadeel - 06.06.2024 Worked ! Thank you so much admin ! RE: log KNX TP load - Hadeel - 09.06.2024 I followed the code in the thread but I sometimes encounter the value over hundred up to 700 ....! Is this normal ? RE: log KNX TP load - admin - 10.06.2024 How did you setup this script? It should be a scheduled script that runs every minute. RE: log KNX TP load - Hadeel - 11.06.2024 Oh I see....my script runs every 20 minutes! I fixed it to calculate every minute and it looks fine now Thank you again admin! |
