Network Switch Control with SSH - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Network Switch Control with SSH (/showthread.php?tid=5468) |
Network Switch Control with SSH - jamesng - 17.06.2024 I'd like to SSH into our Unifi Switches to run a 1 line command to turn on/off a POE connected device. While a POE reboot is is possible with the Unifi API, switching a port off for an extenede period of time is not - so SSH seems like a simple solution. This is the command that need to be executed Code: ssh admin@192.168.1.100
<enter password as prompted>
swctrl poe set off id 45How does one SSH to the switch at 192.168.1.100 from a lua script? If it helps, one can connect to the Unifi switch with a SSH key instead of a password. Many thanks in advance Kind Regards James RE: Network Switch Control with SSH - admin - 17.06.2024 Check this: https://forum.logicmachine.net/showthread.php?tid=176&pid=742#pid742 RE: Network Switch Control with SSH - jamesng - 17.06.2024 Thanks for pointing me at that thread - I generated a key and using io.readproc(run) am now able to send SSH commands to the Unifi switch to control the POE ports. Kind Regards James |
