Add a text as variable in a SQL query - Printable Version
+--- Thread: Add a text as variable in a SQL query (/showthread.php?tid=5469)
Add a text as variable in a SQL query - kike - 18.06.2024
Hi everyone,
I have problemas adding a string variable into a query.
This works fine;
require('luasql.mysql')
require('json')
http = require('socket.http')
env = luasql.mysql()
dbcon, err = env:connect('knx', 'root','123123', '192.168.6.19', '3306')
log(dbcon, err)
dbcon:execute('INSERT INTO test (name, value) VALUES ("Name1", "11")')
dbcon:execute('INSERT INTO test (name, value) VALUES ("Name2", "22")')
but i'm struggling with no success when I try to add both fields as local variables, for example
require('json')
log(dbcon, err)
local nameparam = 'NameX'
local valueparam = 1000
I can't find the right string parametrization or contatenarion to create the right query
something is tricking me with the '  and " that I cant solve
Any help is wellcome!!
Thanks!!
Kike
RE: Add a text as variable in a SQL query - admin - 18.06.2024
Try this:
nameparam = dbcon:escape('NameX') valueparam = 1000 dbcon:execute("INSERT INTO test (name, value) VALUES ('" .. nameparam .. "', " .. valueparam .. ")")
RE: Add a text as variable in a SQL query - kike - 18.06.2024
(18.06.2024, 12:16)admin Wrote: Try this:
it Works!! Thanks!!
RE: Add a text as variable in a SQL query - kike - 19.06.2024
Hi again, I'm sorry for bothering again, but I dont understand how the " and single ' works formating the text.
I need to add more text fields, and I tried to copy or understand the format but the query responds with:
string: LuaSQL: error executing query. MySQL: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'kWh Calor', kike', 1000)
and the script:
require('json')
log(dbcon, err)
dbcon:execute('SET NAMES utf8')
instalacion_param = dbcon:escape('Building_1')
medida_param = dbcon:escape('P1_2A kWh Calor')
usuario_param = dbcon:escape('kike')
valor_param = 1000
log(dbcon:execute("INSERT INTO test2 (instalacion, medida, usuario, valor) VALUES ('" .. instalacion_param .. "', " .. medida_param .. "', " .. usuario_param .. "', " .. valor_param .. ")"))
What's the difference beetween " and ' dealing with test format in this case? Is there any manual or tip abouts this issue?
Thanks in advance!!
RE: Add a text as variable in a SQL query - admin - 19.06.2024
You are missing a single quote before " .. medida_param
You can use Lua multi-line string syntax to make it code more readable:
query = [[   INSERT INTO test2 (instalacion, medida, usuario, valor)   VALUES (     ']] .. instalacion_param .. [[',     ']] .. medida_param .. [[',     ']] .. usuario_param .. [[',     ]] .. valor_param .. [[   ) ]] log(dbcon:execute(query))
Lua strings can be wrapped in single or double quotes. But MySQL expects parameters to be wrapped in single quotes.
works perfect!! This way I cand ajust the number and type of variable to my needs!!
Thanks!! thats what I needed
