[Resolve] enocean package for usb gateway - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: [Resolve] enocean package for usb gateway (/showthread.php?tid=547) |
[Resolve] enocean package for usb gateway - mlaudren - 10.01.2017 Hi, Where can we find all package to use enocean usb gateway on LM2? I have a USB300 and USB310 and would like to make some test with it. thanks! RE: enocean package for usb gateway - admin - 13.01.2017 Which LM2 version is that? Can you tell me what do you have in System config -> Status -> System status? RE: enocean package for usb gateway - mlaudren - 13.01.2017 I'm using LM2i FW and it's CPU model ARM926EJ-S rev 5 (v5l) RE: enocean package for usb gateway - admin - 14.01.2017 Here you can find all additional packages, including EnOcean: https://dl.openrb.com/lm-16.09/pkg/ RE: enocean package for usb gateway - mlaudren - 15.01.2017 Thanks! RE: enocean package for usb gateway - mlaudren - 16.01.2017 Ok, Found something strange. The enocean GW even if found by the system (appear in System status -> serial port: /dev/ttyUSB0 FTDI - FT232R USB UART) is not available in the enocean tab if plugged on a usb hub. If I don't put the hub it's working fine.... Any idea? Is it possible to add a config button like modbus and others protocol to manually enter the GW device? RE: enocean package for usb gateway - admin - 16.01.2017 The currently published version does not support USB hubs, but the new version will. RE: enocean package for usb gateway - mlaudren - 16.01.2017 Great do you have a release date for RC/Beta yet?
RE: [Close] enocean package for usb gateway - gilles38 - 22.06.2017 Any update on this topic ? RE: [Close] enocean package for usb gateway - admin - 22.06.2017 It should work in latest RC firmware. RE: [Close] enocean package for usb gateway - mlaudren - 23.06.2017 Nice, I'll test in the coming days
RE: [Close] enocean package for usb gateway - mlaudren - 27.06.2017 Hi Admin, I try with lm2i FW, but I'm not able to see enocean tab, and when I try to install the enocean-genohm-scada package I have the error in attachment. Any idea what's wrong? Thanks! RE: [Close] enocean package for usb gateway - admin - 28.06.2017 Do you have any packages listed in system config - packages? RE: [Close] enocean package for usb gateway - mlaudren - 28.06.2017 (28.06.2017, 09:17)admin Wrote: Do you have any packages listed in system config - packages? I didn't install it correctly. I tryed inside Apps pages. In System-packages, it's working. Will try it tonight. Thanks! RE: [Close] enocean package for usb gateway - mlaudren - 28.06.2017 It's working! Thanks for the update
