KNX IP Parallel connections - Printable Version
+--- Thread: KNX IP Parallel connections (/showthread.php?tid=5477)
KNX IP Parallel connections - Krstfr2k - 21.06.2024
Hello, I was wondering how many KNX IP tunneling connections in parallel the LM can handle?
RE: KNX IP Parallel connections - Daniel - 21.06.2024
There is no limit but the hardware has some limits, some years ago I tested 6 and worked fine.
RE: KNX IP Parallel connections - Krstfr2k - 21.06.2024
(21.06.2024, 06:59)Daniel Wrote: There is no limit but the hardware has some limits, some years ago I tested 6 and worked fine.
Ok thank you!
We have a project where there are 3 continous KNX tunnelling IP connections to the LM, and it may occasionally be used as a programming interface as well.
RE: KNX IP Parallel connections - manos@dynamitec - 25.06.2025
Hello Daniel, admin,
Can LM5Lp2 support more than one KNX IP Tunneling connections at the same time? If yes, is there any way to set a unique KNX physical address for each tunnel?
Kind Regards,
Manos
RE: KNX IP Parallel connections - Daniel - 25.06.2025
LM supports multiple tunneling connections but the address always will be the same.
(25.06.2025, 11:48)Daniel Wrote: LM supports multiple tunneling connections but the address always will be the same.
Thank you for the clarification. Maybe a nice to have feature for the future though Smile.
Regards,
Manos
You are still connecting to the same device so address should be the same.
