modbus - negative values - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: modbus - negative values (/showthread.php?tid=5479) |
modbus - negative values - Fahd - 21.06.2024 Hi!, I'm having trouble reading negative values (analog-value , Holding register) from a Modbus device using profiles. Specifically, I'm trying to read a value that should be -10, but I’m getting 65436 from the LM5. Thanks in advance { "name": " Temperature Control Outdoor Air Curve Outdoor Air 1 Setpoint ", "bus_datatype": "float16", "type": "register", "address": 1100,"units": "°C" , "value_multiplier": 0.1, "writable": 1}, RE: modbus - negative values - Daniel - 21.06.2024 Did you try different datatype? RE: modbus - negative values - admin - 21.06.2024 Default "datatype" is "uint16", you need to add "datatype": "int16" to your profile. RE: modbus - negative values - Fahd - 21.06.2024 (21.06.2024, 09:57)admin Wrote: Default "datatype" is "uint16", you need to add "datatype": "int16" to your profile.I change it to this (bellow) and still have the same issue { "name": " Temperature Control Outdoor Air Curve Outdoor Air 1 Setpoint ", "bus_datatype": "float16", "dataype": "int16" , "type": "register", "address": 1100,"units": "°C" , "value_multiplier": 0.1, "writable": 1}, { "name": " Temperature Control Outdoor Air Curve Outdoor Air 2 Setpoint ", "bus_datatype": "float16", "dataype": "int16" ,"type": "register", "address": 1101,"units": "°C" , "value_multiplier": 0.1, "writable": 1}, RE: modbus - negative values - Daniel - 21.06.2024 What is documentation saying about this register? RE: modbus - negative values - admin - 21.06.2024 You have a typo in your profile field: dataype instead of datatype RE: modbus - negative values - Fahd - 21.06.2024 (21.06.2024, 10:13)Daniel Wrote: What is documentation saying about this register? Variable_Type : HoldingRegisters Variable_Index : 1100 Scale : - 1 Data_Type : 16bit signed Access : R/W Unit : °C Range : -300 to 450 (21.06.2024, 10:15)admin Wrote: You have a typo in your profile field: dataype instead of datatype Thaaanks a lot |
