SSH access - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: SSH access (/showthread.php?tid=55) |
SSH access - piggel - 01.08.2015 Hi, After upgrade to 20150220 I found out that there also seems to run an ssh server on the LM (i don't know if it was there before). From what I saw it is linked to the remote diagnostics service (if you disable remote diagnostics, the ssh connection is refused). I tried to login but it does not seem to accept the admin user and password. Root seems to be accepted as a valid user (at least no error in the log) but I can't figure out what password is set for root. Does somebody know how to login by ssh? Does somebody know the default root password -> I want to login and change it as I do not like having systems around with default root passwords? Thanks in advance Piggel RE: SSH access - edgars - 03.08.2015 Hi Piggel, SSH is there for remote support purpose only. The access for users are restricted so the system operating stability is not interfered. github dump - BertM - 14.01.2020 Dear Sir, Can you provide me under whitch software license this product is released ? Or on which modidification of the original ? Please advise as similar products exist with exact the same firmware. Regards, Bert RE: SSH access - Daniel - 14.01.2020 What do you mean similar product exist? |
