Bacnet BBMD - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Bacnet BBMD (/showthread.php?tid=5512) |
Bacnet BBMD - Catalin04 - 12.07.2024 Hi, I have an issue with the functionality of the Logic Machine—the BBMD. I'm integrating in a place where we need to add many devices under a BMS using the BACnet Protocol. Unfortunately, the devices are on a different network than the LM and there are a minimum of 3 routers in the middle. I've noticed that the Logic Machine had the BBMD Function. But, during many tests, the only result that I've got is similar to the "Foreign Device" Functionality ( just the Logic Machine and no other device), not the BBMD Functionality ( the Logic Machine as a "Bridge or Gateway" and all the BACnet device in the same net ). As a base for the tests, I've used YABE and an Automation Server From S.E., trying to acquire the points from the Logic Machine and the other BACnet object in the same line. Is there anyone who successfully integrates many objects and an LM using this one with the BBMD? Are there any libraries needed? Thank You in Advance RE: Bacnet BBMD - Daniel - 12.07.2024 LM is only Foreign Device. |
