localhost socket stuck with specific data ? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: localhost socket stuck with specific data ? (/showthread.php?tid=5515) |
localhost socket stuck with specific data ? - Hadeel - 16.07.2024 Hi! I have a project with Lutron integration and I follwed the thread below to setup Lutron library. https://forum.logicmachine.net/showthrea...ght=lutron As I have a lot of group addresses which requires to send command to Lutron server, I have setup localhost socket inside LM as always, in order to unite the place to open TCP port for Lutron. My scripts are below. Event script to simulate Lutron button press and release. Code: --1 ALL ON
--2 Reading
--3 Relax
--4 Goodnight
--5 ALL OFF
--18 Dim down
--19 Dim up
--20 Dim down button release (stop dimming)
--21 Dim up button release (stop)
device = '5101'
value = event.getvalue()
if value == 20 then
cmd = '#DEVICE,'..device..',18,4\r\n'
log(cmd..'_dim down↓stop')
elseif value == 21 then
cmd = '#DEVICE,'..device..',19,4\r\n'
log(cmd..'_dim up↑stop')
cmd = '#DEVICE,'..device..','..value..',3\r\n'
sock = require('socket').udp()
log(cmd..'_sent to udp socket in the event')
sock:sendto(cmd, '127.0.0.1', 5485)
sock:close()Resident script which collects the udp information and send to Lutron server (address "10/1/2" indicates if there is a conection error with Lutron server) Code: require('user.lutron')
require('socket')
if not server then
server = socket.udp()
server:setsockname('127.0.0.1', 5485)
data = server:receive()
if data then
log(data..'_data before sent to lutron tcp')
tcp, err = lutron_login()
if not tcp then
grp.checkwrite('10/0/2', true)
log('no connection to device', err)
if tcp == nil then
tcp:send(data)
log(data)
os.sleep(0.3)
if tcp == nil then
elseif lutron_receive(tcp)~= nil then
if lutron_receive(tcp)[1] ~= nil then
if lutron_receive(tcp)[1]== "no connection to device" then
log(lutron_receive(tcp)[1])
endWhen I execute the event above, this is what I can see in the log. For some reason, when I send val 18 or 19 to press dim up /down button on lutron I cannot send button release command (val 20 or 21) within next 20 seconds even though I simulate to press them way earlier than that. This happens only when I send val 18 or 19 to this event....how am I making the socket stuck? RE: localhost socket stuck with specific data ? - admin - 17.07.2024 You resident script opens a new connection for each message that should be sent. At some point the connection limit is reached. You can try opening the connection and sending the command directly from the event script. Otherwise the resident script must be modified to have only a single open connection. RE: localhost socket stuck with specific data ? - Hadeel - 17.07.2024 Thank you for your reply! OK.....I guess it is because the resident script runs lutron_login() every time? Does this code look better? Code: require('user.lutron')
require('socket')
if not server then
--server:settimeout(3)
if data then
if not tcp then
if tcp == nil then
tcp:send(data)
os.sleep(0.3)
endRE: localhost socket stuck with specific data ? - admin - 18.07.2024 Try this. It will try sending the data again if the first send call failed due to a closed socket or any other error. Remove log() calls once you get it working. Code: if not server then
require('socket')
function send(data)
if not sock then
sock, err = lutron_login()
if not sock then
log('lutron login failed', err)
if sock then
res, err = sock:send(data)
if res then
return true
log('lutron send failed', err)
sock:close()
sock = nil
if data then
if not send(data) then
send(data)
endRE: localhost socket stuck with specific data ? - Hadeel - 18.07.2024 Thank you so so much! It works and I don't see the send delay anymore.... internal socket does not get stuck also. I guess I am opening TCP port each time I run this resident script as well ? I tried to edit them like you did but I am failing....could you suggest how to modify it to have only a single open connection? Code: require('user.lutron')
if not tcp then
while tcp do
res, err = lutron_receive(tcp)
log(res,err)
if (res == nil) then
return
endBy the way in this project we have iOS tablet app and phone app but the frontend does not have functionality to prevent user from continuously clicking on the command button. That is why I put os.sleep(0.3) every time after sending TCP command but do you have better way to prevent high load caused by users' over-clicking ? Thank you very much for your help as always! RE: localhost socket stuck with specific data ? - Hadeel - 22.07.2024 Trying to work on this but I am still keep failing.... With the status script above(with 0 sec interval), I figured out new connection is open every 10 seconds. I guess it is because of the timeout that I set inside lutron_connect script Code: function lutron_connect()
local tcp = assert(socket.tcp())
tcp:settimeout(10)
local res, err = tcp:connect('172.16.1.10', 23)
if res then
return tcp
tcp:close()
return nil, err
endWhat I have tried with modifying status script is as below but it creates an infite roop inside LM.... Appreciate a lot if you could help. Thank you so much! Code: if not tcp then
if not tcp then
while tcp do
return
log(res)
if (err ~= nil) then
alert('Lutron error '..err)
endRE: localhost socket stuck with specific data ? - admin - 22.07.2024 Try this: Code: if not tcp then
if not tcp then
os.sleep(5)
while tcp do
if res then
log(res)
elseif err == 'closed' then
tcp:close()
tcp = nil
end |
