 Multicast issue - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Multicast issue (/showthread.php?tid=5523)  |
Multicast issue - balatis - 19.07.2024 Hello, We are working on a project with 4 lines, 4 IP Routers and 1 LM. When we configure LM with the following settings*(attached photo), the multicast connection is interrupted and the IP routers are not shown in ETS- KNX Connections. No filters are active. Why this happens? Thank you in advance. RE: Multicast issue - Daniel - 19.07.2024 Can you try disabling Pass individual telegrams option and see if it is still happening? RE: Multicast issue - balatis - 19.07.2024 (19.07.2024, 16:19)Daniel Wrote: Can you try disabling Pass individual telegrams option and see if it is still happening? The problem still remains. RE: Multicast issue - Erwin van der Zwart - 20.07.2024 Is the LM only connected to IP or also to a TP line? RE: Multicast issue - balatis - 20.07.2024 (20.07.2024, 07:21)Erwin van der Zwart Wrote: Is the LM only connected to IP or also to a TP line? Only connected to IP. RE: Multicast issue - Erwin van der Zwart - 20.07.2024 Do you have a managed switch? RE: Multicast issue - balatis - 20.07.2024 (20.07.2024, 08:29)Erwin van der Zwart Wrote: Do you have a managed switch? No, the switch is unmanaged. RE: Multicast issue - admin - 22.07.2024 Can you run Wireshark on your PC and provide traffic capture for both cases - when LM is connected or not? Use this filter: _ws.col.protocol=="KNXnet/IP" Export using File > Export Specified Packets, make sure that only Displayed packets are exported. RE: Multicast issue - balatis - 27.07.2024 (22.07.2024, 08:33)admin Wrote: Can you run Wireshark on your PC and provide traffic capture for both cases - when LM is connected or not? OK, thank you for the response. The project is far away, so we will try it when we are there. RE: Multicast issue - JMemphix - 31.07.2024 Is there a preference between using Multicast and IP addressing? Could asked for both IP Routers, and again for LM5s. RE: Multicast issue - admin - 31.07.2024 Tunneling allows only one-to-one connections while Routing (multicast) allows communication between multiple KNX/IP devices on the same network. If you have more than 2 KNX/IP devices then multicast must be used. RE: Multicast issue - balatis - 07.09.2024 Hello! The issue we had, has been solved. The router, by default, didn't allow multicast communication. That was the reason. Thank you for your time and responses.  |
