W4K - Touch 4 - Widget text colour - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: W4K - Touch 4 - Widget text colour (/showthread.php?tid=5524) |
W4K - Touch 4 - Widget text colour - kisevcompany - 20.07.2024 Hello, guys! I couldn`t find a way to change the colour of the text that I`m showing in the picture. Please let me know if there is a way! Thank you so much!! RE: W4K - Touch 4 - Widget text colour - Daniel - 22.07.2024 Is this just text element on custom widget or what? Text element has font color but Touch is not the same app as Mosaic. RE: W4K - Touch 4 - Widget text colour - Erwin van der Zwart - 22.07.2024 Under Touch Config -> Configuration Wheel -> Styles you can add this into the custom CSS to change the color(s) Code: .se-button-multi-title-light-switch.se-button-multi-title-1 {
color: red;
.se-button-multi-title-light-switch.se-button-multi-title-2 {
color: blue;
.se-button-multi-title-light-switch.se-button-multi-title-3 {
color: green;
.se-button-multi-title-light-switch.se-button-multi-title-4 {
color: yellow;
.se-button-multi-title-light-switch.se-button-multi-title-5 {
color: orange;
.se-button-multi-title-light-switch.se-button-multi-title-6 {
color: pink;
}RE: W4K - Touch 4 - Widget text colour - kisevcompany - 01.08.2024 (22.07.2024, 09:03)Erwin van der Zwart Wrote: Under Touch Config -> Configuration Wheel -> Styles you can add this into the custom CSS to change the color(s)Thank you, solved my problem! |
