Could be possible to change objects inside a widget? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Could be possible to change objects inside a widget? (/showthread.php?tid=5531) |
Could be possible to change objects inside a widget? - Ceros2112 - 25.07.2024 Hello, I think that is not possible, but it could be useful: is there a way to create a dataset of objects that you can select with an index? The purpose is, for example, to make a widget (only one) and switch data in it by changing the index value, doing so you can deduplicate widgets and make faster modifications. RE: Could be possible to change objects inside a widget? - Daniel - 25.07.2024 https://forum.logicmachine.net/showthread.php?tid=2717&pid=17512#pid17512 |
