Reflashing LM4 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Reflashing LM4 (/showthread.php?tid=5554) |
Reflashing LM4 - unaxboy - 05.08.2024 Hello everybody! I ran into a problem. After power failure LogicMachine4 stopped working correctly. I can't log in to the system settings. It requires to enter login and password, but after entering it asks its again and again (I enter everything correctly, I'm sure). This happens until I hard reset power, after some time the same issue. I tried to update to lastest firmware (2021.12 installed), but after update, old firmware remains and nothing changes. Reset (10+10 seconds) also does not work, all data remains. I tried to reflashing a microsd card according to instruction, whole process went without errors. But now web interface doesn't load and green led flashing on LM. If I reflashing backupĀ image, nothing loads either. Already tried everything, nothing helps. I read entire forum and found no solution. Please help me! RE: Reflashing LM4 - admin - 06.08.2024 Micro SD card in your LM became read-only. Get a new micro SD, preferably industrial or high endurance. Then follow this guide: https://kb.logicmachine.net/misc/reflash-lm-and-streaming-player/ RE: Reflashing LM4 - unaxboy - 06.08.2024 (06.08.2024, 05:42)admin Wrote: Micro SD card in your LM became read-only. Get a new micro SD, preferably industrial or high endurance. Then follow this guide: https://kb.logicmachine.net/misc/reflash-lm-and-streaming-player/ Thank you, it's works! |
