standart RGB widget - Printable Version
+--- Thread: standart RGB widget (/showthread.php?tid=5559)
standart RGB widget - almoisey - 08.08.2024
Hello. Standart RGB mosaic widget for 3byte color have dimmer slider, but widget for visualisation don't have it. How to add slider to 1.widget?
RE: standart RGB widget - admin - 08.08.2024
RGB color picker does not use a slider because you can select both color and intensity/brightness using a single picker. It's not possible to add a slider there.
RE: standart RGB widget - CristianAgata - 08.08.2024
(08.08.2024, 11:34)admin Wrote: RGB color picker does not use a slider because you can select both color and intensity/brightness using a single picker. It's not possible to add a slider there.
Hi admin,
I take the opportunity to ask if it is possible in the future add colour picker in a mosaic widget.
Best regards Cristian
RE: standart RGB widget - admin - 12.08.2024
Thanks for the suggestion but Mosaic is not developed anymore. Only bug fixes are provided.
RE: standart RGB widget - Novodk - 18.08.2024
(12.08.2024, 08:29)admin Wrote: Thanks for the suggestion but Mosaic is not developed anymore. Only bug fixes are provided.
eta on the new "app"? Can't wait
