How to run a scheduled event at Solar Noon? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: How to run a scheduled event at Solar Noon? (/showthread.php?tid=5574) |
How to run a scheduled event at Solar Noon? - sgraystar - 23.08.2024 With solar panels installed there is an advantage to schedule events when solar generation is likely at a maximimum. There are advanced approaches using solar forecasts, but a simple approach is to use a scheduler event to run at SolarNoon +/- offset, similar to current run at Sunrise +/- offset. I realise this can be done wholly by scripting but would prefer to retain the ability to use the scheduler gui. If an event is configured to run at Sunrise +/- offset via the GUI, is it possible to script an replacement of the start time with some other value such as a simplified solarNoon = (sunrise + sunset)/2? Any ideas? This is a little clumsy, but using event name is one way of adding solarNoon by the existing gui. What would be the equivalent of ' io.writefile('/tmp/lm-scheduler-clear', '')' for the clipsal/schneider firmware? Code: local name = 'solarNoon%'
local maxOffsetHours = 6 -- avoid 24hr boundaries
for _, evt in ipairs(db:getall('SELECT * FROM scheduler_events WHERE name LIKE ?', name)) do
if evt then
local _, _, plusMinus, offsetHour, offsetMin = string.find(evt.name, "^solarNoon%s*([+-])%s*(0[0-"..maxOffsetHours.."])([0-5]%d)%D*")
if plusMinus and offsetHour and offsetMin and evt.type == '' then
local sunrise, sunset = rscalc(latitudeMel, longitudeMel)
local solarNoon = math.floor(((sunset + sunrise) / 2) + 0.5)
local offsetMinutes = (offsetHour * 60) + offsetMin
local eventMinutes
if plusMinus == '+' then
eventMinutes = solarNoon + offsetMinutes
eventMinutes = solarNoon - offsetMinutes
local eventStartHour = math.floor(eventMinutes / 60)
local eventStartMin = math.floor(eventMinutes % 60)
db:update('scheduler_events', {
start_hour = eventStartHour,
start_min = eventStartMin
}, { id = evt.id })
-- io.writefile('/tmp/lm-scheduler-clear', '')
log("Error. '"..evt.name.."' event name must begin with 'solarNoon[+-]HHMM ...' where max HH = 0"..maxOffsetHours..", and event setting 'Run at:' = 'Specific time'")
endRE: How to run a scheduled event at Solar Noon? - sgraystar - 03.09.2024 revised script Code: --[[
Warning: database functions are subject to change with firmware updates.
-- Update the start time for any solarNoon scheduler events.
local namePrefix = 'solarNoon%'
local maxOffsetHours = 8 -- avoid 24hr boundaries
local namePattern = "^solarNoon%s*([+-])%s*(0[0-"..maxOffsetHours.."])([0-5]%d)%D*"
local typeSpecificTime = ''
for _, evt in ipairs(db:getall('SELECT * FROM scheduler_events WHERE name LIKE ?', namePrefix)) do
if evt then
if (type(evt.start_hour) == "number") and (evt.start_hour % 1 == 0) and (type(evt.start_min) == "number") and (evt.start_min % 1 == 0) and (type(evt.type) == 'string') then
local _, _, plusMinus, offsetHour, offsetMin = string.find(evt.name, namePattern)
if plusMinus and offsetHour and offsetMin and (evt.type == typeSpecificTime) then
local solarNoon = math.floor(((sunset + sunrise) / 2) + 0.5) -- approximation
local eventMinutes
if (evt.start_hour ~= eventStartHour) or (evt.start_min ~= eventStartMin) then
}, { id = evt.id })
log("Error. '"..evt.name.."' event name must begin with 'solarNoon[+-]HHMM' where max HH = 0"..maxOffsetHours..", and event setting 'Run at:' must be 'Specific time'")
log("Error. Firmware change, check evt.start_hour and evt.start_min are integers, and evt.type is a string.", evt)
end |
