Modbus script problem - Timeout - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Modbus script problem - Timeout (/showthread.php?tid=5577) |
Modbus script problem - Timeout - fleeceable - 27.08.2024 Hi! I'm facing some problems with modbus script over some time. After some time (about week or two) communication goes to timeout (all reading/writing parameters). After I disable modbus script, enabling port on modbus tab, going to scan modbus devices on specific port (and system finds device with address), disable port on modbus tab, enable script again - everything starts to work again via script. I attach code in here. What can cause this? Resident script with 10s sleep Mitsubishi frequency converter Code: require('luamodbus')
vent_command = grp.getvalue('1/3/13')
reset_command = grp.getvalue('34/1/4')
control_motor = true
motor_on = vent_command
speed_value_perc = grp.getvalue('34/1/2')
hz_sp = math.floor(speed_value_perc*50)
mb = luamodbus.rtu()
mb:open('/dev/RS485-2', 19200, 'E', 8, 1)
mb:connect()
mb:setslave(5)
speed_read,err= mb:readregisters(202)
--log('Speed read22',speed_read,err)
read_mode,err= mb:readregisters(8)
--log('Read mode',read_mode,err)
read_speed,err= mb:readregisters(13)
log('Read speed',read_speed,err)
read_inputs,err= mb:readregisters(214)
--log('Read inputs',read_inputs,err)
read_alarm,err= mb:readregisters(500)
--log('Read alarms',read_alarm,err)
if control_motor then
if motor_on then
if read_mode ~= 75 then
res,err = mb:writeregisters(8,2)
--log('Write_motor_to_on',res,err)
if read_speed ~=hz_sp then
res,err =mb:writeregisters(13,hz_sp)
--log('Write_motor speed',res,err)
if read_mode ~= 0 then
res,err = mb:writeregisters(8,0)
--log('Write motor off',res,err)
if reset_command then
--log('Reseting frequency converter')
log(mb:writeregisters(1,1))
grp.checkupdate('34/1/4', 0)
mb:close()
if read_mode == 75 or read_mode == 67 then
grp.update('34/1/3', read_speed/50)
elseif read_mode == 0 then
grp.update('34/1/3', 0)
endI have seen this kind of problem with some other devices as well (chiller cooling units and swegon ventilation unit). RE: Modbus script problem - Timeout - Daniel - 27.08.2024 Try adding mb:flush() after setslave. Why don't you use profile? RE: Modbus script problem - Timeout - fleeceable - 29.08.2024 Thanks! Gonna try that. One reason is that I like coding and I usually have custom projects where modbus part is custom every time. To create profile and test it is quite time consuming compared with coding. |
