Change attribute in visu following a knx object - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Change attribute in visu following a knx object (/showthread.php?tid=5580) |
Change attribute in visu following a knx object - Andrea Becagli - 27.08.2024 I have been asked to make some elements of the visualization "read-only" if a specified KNX object is off. Is there a way I can do this? RE: Change attribute in visu following a knx object - admin - 27.08.2024 See this: https://forum.logicmachine.net/showthread.php?tid=319&pid=8921 RE: Change attribute in visu following a knx object - Andrea Becagli - 27.08.2024 Okay, I saw the example. I am trying to make it work, but I need to know if it is possible to use more than one "additional class" per object since I already have a generic class handling the animations of all the buttons, and I need this to happen to just a bunch of those. RE: Change attribute in visu following a knx object - admin - 27.08.2024 You can set any number of additional classes, separated by space. RE: Change attribute in visu following a knx object - Andrea Becagli - 27.08.2024 Does not seem to be working, I probably got something wrong I pasted this in in my javascript custom: Code: $(function() {
if (typeof grp != 'object') {
return;
grp.listen('32/1/22', function(object, state) {
$('.dis_da_totale').toggleClass('el-disabled', object.value == false);
});pasted this in Custom CSS: Code: .el-disabled {
opacity: 0.5;
.el-disabled,
.el-disabled * {
pointer-events: none !important;
}and I used dis_da_totale as an additional class for the button is that correct, or am I missing something? RE: Change attribute in visu following a knx object - admin - 27.08.2024 Your example works fine for me. Use browser dev tools (F12) to check if the element has a specific class. RE: Change attribute in visu following a knx object - Andrea Becagli - 27.08.2024 Maybe then I did not understand what i supposed to do. Like I expected the button to stop working as long as the value of "32/1/22" is false. Is this correct? RE: Change attribute in visu following a knx object - Erwin van der Zwart - 27.08.2024 (27.08.2024, 11:59)admin Wrote: Your example works fine for me. Use browser dev tools (F12) to check if the element has a specific class. I think he did not also add the class el-disabled to the additonal classes so the CSS does not apply to the element because of the class dis_da_totale is used, so intthis case the additional class needs to hold both dis_da_totale el-disabled or am i wrong? RE: Change attribute in visu following a knx object - Andrea Becagli - 27.08.2024 (27.08.2024, 14:11)Erwin van der Zwart Wrote:(27.08.2024, 11:59)admin Wrote: Your example works fine for me. Use browser dev tools (F12) to check if the element has a specific class. I just tried that but it makes the element disabled no matter what the value is. I forgot to say that I checked with dev tools and the element seems to have the "dis_da_totale" class RE: Change attribute in visu following a knx object - admin - 27.08.2024 Post a screenshot of the relevant visualization element settings. RE: Change attribute in visu following a knx object - Andrea Becagli - 27.08.2024 (27.08.2024, 14:24)admin Wrote: Post a screenshot of the relevant visualization element settings. I have attached two screenshots: the settings and the actual visu. "uso TOTALE OFF" is the object which should lock the buttons below RE: Change attribute in visu following a knx object - admin - 28.08.2024 Send your backup via PM. Use WeTransfer or another similar service. RE: Change attribute in visu following a knx object - Andrea Becagli - 28.08.2024 (28.08.2024, 13:58)admin Wrote: Send your backup via PM. Use WeTransfer or another similar service. Here you go: https://we.tl/... RE: Change attribute in visu following a knx object - admin - 29.08.2024 It's not working because the previous function in Custom JavaScript fails with an error. Change it to this and it will work: Code: $(function(){
$('.slider-alt').each(function(_, el) {
var $el = $(el), addr = $el.data('object'), icon = $el.find('.icon');
if (addr) {
grp.listen(addr, function(obj) {
var val = obj.value || false;
//val = Math.round(2.55 * (100 - val));
var name = el.getAttribute('data-object-name');
el.textContent = name
});RE: Change attribute in visu following a knx object - Andrea Becagli - 29.08.2024 (29.08.2024, 15:49)admin Wrote: It's not working because the previous function in Custom JavaScript fails with an error. Change it to this and it will work: Thanks, admin. Problem solved as always
