Scheduler as google calendar - Printable Version
+--- Thread: Scheduler as google calendar (/showthread.php?tid=5581)
Scheduler as google calendar - Domoticatorino - 28.08.2024
Dear all,
a customer of mine has to manage many schedulers per a variable. Even if LM scheduler usually  is very usefull, for this purpose I should simplify.
Is there a way to manage or integrate a google calendar?
RE: Scheduler as google calendar - admin - 28.08.2024
Our partners have a paid solution for Google calendar: https://www.knxlogic.eu/product/ics-knx-gateway-add-on/
RE: Scheduler as google calendar - cdebackere - 03.09.2024
(28.08.2024, 07:09)Domoticatorino Wrote: Dear all,
Hi Mr Torino Smile
we indeed have an addon library which synchronises with a google calendar.
You can freely define what needs to happen at the start and at the end of the planned calendar event. And even what to do if an event is added, which a start in the past(in case an event was added 'too late' to the calendar. You can also specify that the group address to use sits in the title (or another field) of the event.
A series of predefined, common, action/configuration is in the library, but you can modify as needed, based on complexity you envisage.
The library support all common recurrence types of an event (days/weeks/months/years/...)
PM me if you need more information.
Christof
