swimming pool - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: swimming pool (/showthread.php?tid=5582) |
swimming pool - gjniewenhuijse - 28.08.2024 For an outdoor pool that is yet to be built, I would like to monitor and control it as much as possible from the logic machine. Does anyone have experience with this? It concerns monitoring/controlling: - pool pump (variable speed) - filter (auto backwash) - heat pump heating - lighting (hue compatible) - ph / salt RE: swimming pool - CristianAgata - 30.08.2024 (28.08.2024, 10:03)gjniewenhuijse Wrote: For an outdoor pool that is yet to be built, I would like to monitor and control it as much as possible from the logic machine. Does anyone have experience with this?Hi, I suggest you for first to use a LM5p2-RIO3. It this way you can have I/O and analog value control. About sensors you can use standard sensor with 0/10v output. Best regards Cristian |
