Copy Trends - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Copy Trends (/showthread.php?tid=5588) |
Copy Trends - jmir - 30.08.2024 Hi, Is there any way to export trend logs from a LM and import them to another one? I mean exiting data and trend config. RE: Copy Trends - admin - 30.08.2024 1. Make a backup on destination LM in case something goes wrong 2. Make a backup on source LM 3. Open the backup archive using 7-Zip (https://www.7-zip.org/) and extract storage/db/current.db 4. Open current.db using DB Browser for SQLite (https://sqlitebrowser.org/) 5. Open File > Export > Database to SQL file... 6. Click "Deselect all" then select only trends table 7. Check "Keep column names..." and select "Export data only" 8. Save the file as trends.sql and open it in any text editor 9. Remove first and last line ("BEGIN TRANSACTION;" and "COMMIT;") 10. Wrap each line starting with "INSERT" like this: Code: db:query([[INSERT INTO "trends"...]])11. Delete all trends on destination LM 12. Copy the whole trends.sql file contents and run it as a script on destination LM 13. Refresh the UI and make sure that trends list hes been updated 14. Make a new backup on destination LM 15. Using 7-Zip copy storage/db/trends from source LM backup to destination LM backup 16. Restore the modified backup on destination LM RE: Copy Trends - jmir - 02.09.2024 (30.08.2024, 06:34)admin Wrote: 1. Make a backup on destination LM in case something goes wrong It works prefectly! Thanks! RE: Copy Trends - Domizy - 18.12.2024 Good morning, Could you tell me how to find the correspondence between the knx address and the object number? For example I have a knx address in 0/1/1 and an object number in 257. Thanking you. Kind regards. Antoine RE: Copy Trends - admin - 18.12.2024 Group address formula is X/Y/Z => X * 2048 + Y * 256 + Z. RE: Copy Trends - Domizy - 18.12.2024 (18.12.2024, 09:31)admin Wrote: Group address formula is X/Y/Z => X * 2048 + Y * 256 + Z. Thanks !!
