FTP Access - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: FTP Access (/showthread.php?tid=559) |
FTP Access - gowlogic - 16.01.2017 Hi, i cannot create any file per ftp on my LM3 only reading is possible. Is there any solution for this problem? Thanks RE: FTP Access - admin - 16.01.2017 For generic files you should use ftp username. When using apps username, you cannot upload into base directory. RE: FTP Access - gowlogic - 16.01.2017 But if i connect to my other 5 LM3's i have full access? RE: FTP Access - admin - 16.01.2017 It might work in different version, but still you should use ftp username. RE: FTP Access - gowlogic - 16.01.2017 With FW 20160714 it also doesn't work ![]() why is the authorization is differently? 26.PNG is the LM without full access RE: FTP Access - Re-G - 10.01.2023 Hi. Well i'm stupid. Please tell me how to get access to ftp. I would like to upload file to \user If im connecting to ftp by FileZilla (user name: FTP, pass: (i put pass in systemConfig/Services/FTP server) i can get access to catalog \ but is nothing there. What im doing wrong? RE: FTP Access - admin - 10.01.2023 Use apps username to access user directory. RE: FTP Access - Re-G - 10.01.2023 (10.01.2023, 10:20)admin Wrote: Use apps username to access user directory. One more question - what is default pass? Thanks for help RE: FTP Access - admin - 10.01.2023 There's no default password, you have to set it in System config. RE: FTP Access - Re-G - 10.01.2023 (10.01.2023, 10:27)admin Wrote: There's no default password, you have to set it in System config. Thanks a lot. RE: FTP Access - nonkeldw - 15.04.2023 Hello When i login with user ftp is don't see any directory, only a empty root. When i login with user apps, i see al the directory's like public, cron,... but i can't upload anything to this directory? What do i wrong? I got a Wiser device. Many thanks! RE: FTP Access - Daniel - 17.04.2023 What are you trying to upload and to which location exactly? RE: FTP Access - nonkeldw - 19.04.2023 I want to upload my own created html page created with Chart.js. RE: FTP Access - Daniel - 19.04.2023 Then you should be able to upload it to user directory, is this what you tried? |
