bacnet client slowness - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: bacnet client slowness (/showthread.php?tid=5590) |
bacnet client slowness - Andrea Becagli - 01.09.2024 Hi, I am trying to read/write some values (30ish) in Bacnet to two Isma Controlli modules. I have installed the app, but it seems to be slow in responding (E.g., a binary object goes to 1, and LM receives it after 20 seconds). Could I change something to make this better? I was told using the lua library is faster, but while trying to load the library it gave me an error "module 'bacnet' not found", so I went and downloaded (hoping the bacnet module was inside) the "genohm-scada-bacnet_20230120_imx6.ipk" with its signature "genohm-scada-bacnet_20230120_imx6.sig" but it says it's not valid. I am lost. EDIT: I was trying to upload it as an app not as a package The LM I am using has the latest firmware 2024.04 RE: bacnet client slowness - Daniel - 02.09.2024 So what is the current issue? Make sure to uninstall the app if you use the package and disable bacnet server. |
