trends fetch - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: trends fetch (/showthread.php?tid=5597) |
trends fetch - jmir - 04.09.2024 Hi, There's something that i can't understand on trends.fetch function... If I call it like this, returning timestamps should be in UTC, isn't it? Code: local dates = {
['start'] = os.time({ year = 2024, month = 9, day = 2, hour=0 , min=0, sec=0},true),
['end'] = os.time({ year = 2024, month = 9, day = 3, hour=0 , min=0, sec=0},true),
local yearly = trends.fetch('Trend - Data', dates, nil, true)
local i
for i=1,3,1 do log(i,yearly[i]) endCode: sample 04.09.2024 12:11:31
* arg: 1
* number: 1
* arg: 2
* table:
[1]
* number: 1725238800
[2]
* number: 60032.77
* arg: 1
* number: 2
* arg: 2
* table:
[1]
* number: 1725242400
[2]
* number: 60033.42
* arg: 1
* number: 3
* arg: 2
* table:
[1]
* number: 1725246000
[2]
* number: 60034.42Attached there is an image from trends visualitzation: I thought that on trend visualitzation data is shown in local time but values corresponds to UTC timestamps... Can someone explain me if i'm missing something? RE: trends fetch - admin - 04.09.2024 What is your LM timezone? RE: trends fetch - jmir - 04.09.2024 (04.09.2024, 10:29)admin Wrote: What is your LM timezone? Europe/Madrid RE: trends fetch - admin - 04.09.2024 The timestamp is not exactly UTC but the current timestamp is used as if it was a UTC time. This is needed for days start at 0:00, otherwise the daily data calculation will be wrong. Use this to convert trend timestamp to a formatted date string: Code: os.date('!%d %m %Y %H:%M',value[1])RE: trends fetch - jmir - 04.09.2024 (04.09.2024, 13:11)admin Wrote: The timestamp is not exactly UTC but the current timestamp is used as if it was a UTC time. This is needed for days start at 0:00, otherwise the daily data calculation will be wrong. So if I understant it, inside rrd you're storing a "local timestamp" like this: if now it's "04/September/24 14:00:00 GMT+02:00 DST" you store this timestamp 1725451200+2*3600 Isn't it? RE: trends fetch - admin - 05.09.2024 (04.09.2024, 14:08)jmir Wrote: So if I understant it, inside rrd you're storing a "local timestamp" like this:Yes RE: trends fetch - jmir - 05.09.2024 (05.09.2024, 06:07)admin Wrote:(04.09.2024, 14:08)jmir Wrote: So if I understant it, inside rrd you're storing a "local timestamp" like this:Yes Ok thanks! |
