Text position - Printable Version
+--- Thread: Text position (/showthread.php?tid=56)
Text position - Pawel - 06.08.2015
In some cases I have to dynamically change text on the visualization. To do that I use "custom values" of grups on the object tab.
Problem starts when I want to align in center that text, because "element position" is on the left top corner.
Is there a solution to that problem, to place object not to left top corner, but center of that element?
RE: Text position - admin - 07.08.2015
We have plans to make this configurable in future releases, for now you can use Custom CSS to set a fixed element width and align text to the center. Note that it won't be visible in the editor, only in user visualization.
.myclass {  width: 200px;  text-align: center; }
RE: Text position - buuuudzik - 08.10.2015
(07.08.2015, 06:12)admin Wrote: We have plans to make this configurable in future releases, for now you can use Custom CSS to set a fixed element width and align text to the center. Note that it won't be visible in the editor, only in user visualization.
I write this code:
div.item.item-label {font-family: Calibri !important; color:#009530 !important; text-align: center !important;}
and a font-family and a color of font in visualisation are proper but text-align is still left(default value).
What am I doing wrong?
RE: Text position - admin - 08.10.2015
You have to set fixed width via CSS, otherwise text-align will not work.
(08.10.2015, 10:37)admin Wrote: You have to set fixed width via CSS, otherwise text-align will not work.
It works! Thank you Smile
