Remote login Gira S1 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Remote login Gira S1 (/showthread.php?tid=5605) |
Remote login Gira S1 - tomnord - 06.09.2024 Hello. I'm trying to login via a Gira S1 (ISE). I get to the credentials prompt, but nothing happens when I enter correct credentials. Accessin via zerio tier works fine. Customer is using the S1 for access, so I kinda need it to work. Any ideas? The login attempts from the S1 are flagged as the color RED in access log. RE: Remote login Gira S1 - admin - 09.09.2024 This is a known issue. ISE does not modify the HTTP Host header correctly so LM rejects such requests. For this to work correctly the Host header must be equal to the ISE device IP that sends requests to LM. New firmware will have an option to set a list of allowed HTTP Hosts so ISE connection will work without any changes from their side. At this point we don't know when this firmware will be ready. RE: Remote login Gira S1 - tomnord - 09.09.2024 OK, we made it work with LM cloud instead. Thank you for the reply. |
