Best way to handle lutron switch dimming command - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Best way to handle lutron switch dimming command (/showthread.php?tid=5621) |
Best way to handle lutron switch dimming command - Hadeel - 18.09.2024 Hi! I have phase dimming actuator in KNX panel and I need to control them with Lutron switch. The Lutron switch has 4 buttons; on/off and dim up/down. I have handled the on/off part but I want to seek the best way in LM to imprement the dimming part. From the TCP message coming from Lutron, I know when the button is pressed and released. What I want to do is to dim up/down for 1 step(6%) with short press, and keep dimming up/down with long press until the release, like KNX wall switches. As LM needs to be the one to distinguish between long press and short press, this is what I have done. I created two types of resident script. ・Script to check the Lutron message...when I get the button press message I set storage ('Button1', 'up'), ('Button1', 'down'), and when I get the button release message I set storage ('Button1', 'stop'). Script interval = 0 ・Script to check the Button1 storage variable....if the value is 'up' or 'down', do the relative dimming for 1 step and if the value is 'stop', do nothing. Script interval = 1 sec Code: local array = {'2/4/3', '2/4/2'}
-- Loop through the array
for i = 1, #array do
if storage.get(array[i]) == 'up' then
grp.write(array[i], 14) --dim 1 step up 6 %
elseif storage.get(array[i]) == 'down' then
grp.write(array[i], 6) --dim 1 step down 6 %
endIs there any better, effifient way to handle this ? I don't want to pressure LM to get high load. |
