Importing html to Vis. graphics Icons - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Importing html to Vis. graphics Icons (/showthread.php?tid=5649) |
Importing html to Vis. graphics Icons - Mrinj - 04.10.2024 Hi there! Working on configuring Wiser 2.8.3 for a client and struggling on importing ready HTML setup files into Vis.Graphics, Add Icons/Images/Backgrounds. Using them after that in Visualization, Frame, Url. It's still working on previous Wiser versions up to 2.7.0 on all the other clients. Do you have any advise on work around on this? Thanks! RE: Import html to Vis. graphics Icons - admin - 04.10.2024 Only valid image files are allowed in Vis. graphics. You can upload HTML files via FTP using apps login. Upload to user directory. Then set the URL to http://IP/user/file.html RE: Importing html to Vis. graphics Icons - Mrinj - 04.10.2024 Thank you for the answer! Will try that ☺️ |
