REST with JSON - Printable Version
+--- Thread: REST with JSON (/showthread.php?tid=5655)
REST with JSON - toujour - 05.10.2024
what is the better way to send some JSON values to a REST server ?
Something about this ?
https = require('ssl.https')
url = 'http://IP_MACHINE/url'
body = [[{
"timestamp": NOW(),
"meter": grp.getvalue('32/2/4')
resp = {}
res, code, hdrs, stat = https.request({
  url = url,
  method = 'POST',
  headers = {
    ['Content-Type'] = 'application/json',
    ['Content-Length'] = #body,
  source = ltn12.source.string(body),
  sink = ltn12.sink.table(resp),
resp = table.concat(resp)
log(res, code, hdrs, stat, resp)
How can I use NOW() and grp.getvalue inside of the JSON ?
RE: REST with JSON - CristianAgata - 05.10.2024
(05.10.2024, 08:49)toujour Wrote: Hi,
body = [[{
"timestamp": NOW(),
resp = {}
  url = url,
  method = 'POST',
  headers = {
Hi toujour,
try to add this:
require('json') ora = os.time() value = grp.getvalue('your_group_address') body = json.encode({   timestamp = ora,   meter = value, }) log (body)
best regards Cristian
RE: REST with JSON - toujour - 10.10.2024
It's ok !!
