LM Mirror - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: LM Mirror (/showthread.php?tid=5665) |
LM Mirror - OihanV - 14.10.2024 Hello, Lately, we have been working on several projects for hospitals or medical centers where double security is required for the equipment. Is there any application or way we can use two LM systems in a mirrored setup? That is, so that LM 2 makes backups of LM 1, and when LM 1 crashes or freezes, LM 2 automatically takes over. Thanks You. Regards RE: LM Mirror - Daniel - 14.10.2024 It is quite complex topic but quite a lot can be done here. Depend of the detail project specifications. The redundant LM can keep asking main LM are you alive and if no answer you can enable all the things you want like scripts, KNX, bacnet etc. Make sure not to create KNX loop, changing multicast is the easiest way. See this for project syncing. https://forum.logicmachine.net/showthread.php?tid=1679&pid=10348#pid10348 RE: LM Mirror - guillermo - 14.10.2024 What we are looking for is that it comes made in an application, as if it were the mosaic or lmcloud, we see that it matters to you that it is easy to use and makes copies from one to another, I know it will be expensive for you but you will give a plus in the facilities, and The sale will almost double if you do it right. |
