KNX/TP: Disconnected - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: KNX/TP: Disconnected (/showthread.php?tid=5675) |
KNX/TP: Disconnected - jmir - 16.10.2024 Hi, We've have a device that has been working fine for years, and now is getting this alerts: When connecting to the bus (through LM) using ETS, and when we read device states, most responses are lost... Can it be a SD card issue? Or what can be happening? Thanks. RE: KNX/TP: Disconnected - Daniel - 16.10.2024 It is most likely too big bus traffic. RE: KNX/TP: Disconnected - jmir - 16.10.2024 (16.10.2024, 12:48)Daniel Wrote: It is most likely too big bus traffic. But when I connect using ETS I can't see a lot of traffic... RE: KNX/TP: Disconnected - Daniel - 16.10.2024 What is the bus voltage next to LM? Check the KNX connector. RE: KNX/TP: Disconnected - jmir - 16.10.2024 (16.10.2024, 15:20)Daniel Wrote: What is the bus voltage next to LM? Check the KNX connector. 30.2V RE: KNX/TP: Disconnected - Daniel - 16.10.2024 Do you have another KNX psu to try? RE: KNX/TP: Disconnected - jmir - 17.10.2024 (16.10.2024, 16:04)Daniel Wrote: Do you have another KNX psu to try? Not at the moment... When I go again to the installation I'll try and let you know if it's solved or not. Thanks. |
