Auto OFF function - Printable Version
+--- Thread: Auto OFF function (/showthread.php?tid=5690)
Auto OFF function - eurosting - 21.10.2024
Hello All,
I'm searching for a small script, which switches off a power plug if device in stanby mode for a long time.
For example I'm using MDT AMS16.12 with power measuring function. The TV is connected to the power plug, which is controlled by AMS1216 device.
So after watching TV I forget sometimes to disable the plug.
I looking for a script like:
if TV power plug status =1, but power consumption < 10W for 1 hour,
then disable the plug.
Tried to use FBD editor of WISER, but without succes. Please
advise.
RE: Auto OFF function - RomansP - 21.10.2024
Hello.
Here is the resident script, which will be executed every minute
if not minute_counter then   minute_counter = 0 end plug_status = grp.getvalue('plug_status') -- the object of plug status power_consumption = grp.getvalue('power_consumption') -- the object of power in watts log(minute_counter) --log(plug_status) --log(power_consumption) if plug_status and power_consumption < 10 then   minute_counter = minute_counter + 1 else   minute_counter = 0 end if minute_counter > 59 then -- one hour passed   grp.write('plug_control', false) -- turn off plug (plug control object)   minute_counter = 0 end
RE: Auto OFF function - eurosting - 21.10.2024
Thanks a lot, your script is working perfect!
