maybe I am late to the party - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: maybe I am late to the party (/showthread.php?tid=5697) |
maybe I am late to the party - Andrea Becagli - 22.10.2024 I have done a few tests. I will attach my visu backup and gen backup just in case. MAYBE BUGS - if in additional values/icons in a dimmer I put in 100% the icon goes back to off instead of being in the last stage. This is easy solvable since if you put 101 as max value this does not happen anymore, but still.. - in tile view, once you change from one plan to another, you return to plan view. - frame widget does not change in height but only in width - in a custom widget in compact mode if you select "icon and value" you cannot choose the shape - there are a few widgets where custom css does not work IMPROVEMENTS - it might be that I don't know how to do it but in tile view I feel like I need to see some names otherwise I would just see a bunch of switches I don't know how to identify - In numeric value display, it might be useful to add a unit field so that when a value is shown you can see the units QUESTIONS - how do the functions work (Ex. lights, shades, etc.)? RE: maybe I am late to the party - Daniel - 23.10.2024 Tile view settings has the Title and icon as in Mosaic The functions will be used later for filtering as in Mosaic. RE: maybe I am late to the party - Andrea Becagli - 23.10.2024 (23.10.2024, 08:02)Daniel Wrote: Tile view settings has the Title and icon as in Mosaic Just found out i can put a title in tile view, I thought settings would be the same in vis admin as I change from plan view to tile view. Would it be possible to decide the position of the title? RE: maybe I am late to the party - admin - 23.10.2024 This CSS will center Tile view widget title: Code: .board-item-content__title {
justify-content: center;
}RE: maybe I am late to the party - Andrea Becagli - 31.10.2024 After some more tests... I noticed the categories widget but I don't get it, the way I expected It to work is that I ordered lights under the category, so I have all the lights there. It seems though that you can not actually order the category widget, it just stays at the bottom of the page I tried is creating a custom RGBW widget (switch, circular slider, and RGBW color picker), but it does not let me open the color picker. I guess this is because it's a pop-up widget, right? In custom widget, in plan view, I would like to add a 1-bit object in additional values but I does not let me chose those ones. Is that right? RE: maybe I am late to the party - Daniel - 31.10.2024 Category widget is a known bug Share your backup as not sure what is the problem. for bit object just use switch. RE: maybe I am late to the party - Andrea Becagli - 31.10.2024 (31.10.2024, 16:42)Daniel Wrote: Category widget is a known bug Ok, sorry I did not see it in other's posts I will attach it to this reply Maybe I did not explain myself correctly, while using a custom widget I would like to update the icon color (in plan view) based on the value of a 1-bit object, I don't want to control a 1-bit object. RE: maybe I am late to the party - Andrea Becagli - 27.11.2024 I was trying the new pincode on levels and plans and noticed it did not work while moving through pages via link but only while using the left -side menu. Could that be a bug? RE: maybe I am late to the party - Daniel - 27.11.2024 It is, thanks. RE: maybe I am late to the party - Andrea Becagli - 27.11.2024 Thanks for the fast response! So I was trying the user access app and opening the Visu app (with a temporary account), but it gave me a 405 error. Is Visu right now available only for admins? RE: maybe I am late to the party - Daniel - 27.11.2024 Do not use User access app for now. Only permissions in LogicMachine- User Access. RE: maybe I am late to the party - Andrea Becagli - 28.11.2024 (27.11.2024, 18:46)Daniel Wrote: Do not use User access app for now. Only permissions in LogicMachine- User Access. Ok no problem |
