How to execute a script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: How to execute a script (/showthread.php?tid=5705) |
How to execute a script - Tuwat47 - 25.10.2024 Hi everyone, I don't understand why LM doesn't execute this Event Based script when I upload a Value. I tried to upload GA fmanually, but the result of my calcs don't change, the value is always 0. Can someone explain me how to trigger it? Thanks Code: --Variables App. Dx
AppDx_Consumo_Radiante_Caldo = ("32/1/200")-- consumo radiante caldo Dx
AppDx_Consumo_Radiante_Freddo = ("32/1/201")-- consumo radiante freddo Dx
AppDx_Volume_ACS = ("32/1/202")-- consumo ACS Dx
Energia_Termica_Appartamento_Dx = grp.write("32/1/204") -- uscita
--Variables App. Sx
AppSx_Consumo_Radiante_Caldo = ("32/1/210")-- consumo radiante caldo Sx
AppSx_Consumo_Radiante_Freddo = ("32/1/211")-- consumo radiante freddo Sx
AppSx_Volume_ACS = ("32/1/212")-- consumo ACS Sx
Energia_Termica_Appartamento_Sx = grp.write("32/1/214") -- uscita
-- Other Variables
K = grp.write("32/1/215") -- rapporto conversione elettrico / termico
Consumo_Elettrico_PDC = ("32/1/216")-- consumo elettrico misurato
Consumo_Elettrico_Dx = grp.write("32/1/217")
Consumo_Elettrico_Sx = grp.write("32/1/218")
-------------------------------non toccare più nulla sotto questa riga------------------------------------------
Rad_Heat_Dx = grp.getvalue(AppDx_Consumo_Radiante_Caldo)
Rad_Cool_Dx = grp.getvalue(AppDx_Consumo_Radiante_Freddo)
Acs_Dx = grp.getvalue(AppDx_Volume_ACS)
Rad_Heat_Sx = grp.getvalue(AppSx_Consumo_Radiante_Caldo)
Rad_Cool_Sx = grp.getvalue(AppSx_Consumo_Radiante_Freddo)
Acs_Sx = grp.getvalue(AppSx_Volume_ACS)
Cons_Elet_PDC = grp.getvalue(Consumo_Elettrico_PDC)
-- Energia Termica Appartamento Dx
Energia_Termica_Appartamento_Dx = Rad_Heat_Dx + Rad_Cool_Dx + (Acs_Dx * 40.6)
-- Energia Termica Appartamento Sx
Energia_Termica_Appartamento_Sx = Rad_Heat_Sx + Rad_Cool_Sx + (Acs_Sx * 40.6)
-- Rapporto conversione Cons_Elet_PDC / Consumo_Termico_Totale
K = Cons_Elet_PDC / (Energia_Termica_Appartamento_Dx + Energia_Termica_Appartamento_Sx)
-- Consumo Elettrico Appartamento Dx
Consumo_Elettrico_Dx = K * Energia_Termica_Appartamento_Dx
-- Consumo Elettrico Appartamento Sx
Consumo_Elettrico_Sx = K * Energia_Termica_Appartamento_SxRE: How to execute a script - Daniel - 25.10.2024 A script runs from up to down and you first trying to write and then do the calculation. You should move the write on the bottom. Your write commands are wrong, it should be like this grp.write("32/1/214", Energia_Termica_Appartamento_Sx) RE: How to execute a script - Tuwat47 - 25.10.2024 (25.10.2024, 09:29)Daniel Wrote: A script runs from up to down and you first trying to write and then do the calculation. You should move the write on the bottom. Thanks Daniel, your support has been very useful. I appreciate that. Here the correct script. Code: AppDx_Consumo_Radiante_Caldo = ("32/1/200")-- consumo radiante caldo Dx
-- kWh termici= V × ΔT × 1,16
-- C = 1,16kWh / (m3*°C) calore specifico acqua
-- ΔT = salto termico assunto come 35°C (Temp. ACS= 50°C / Temp. Ingresso= 15°C / ΔT= 35°C)
-- Kconversione = 35 * 1.16 = 40.6
grp.write("32/1/204",Energia_Termica_Appartamento_Dx)
grp.write("32/1/214",Energia_Termica_Appartamento_Sx)
grp.write("32/1/215", K)
grp.write("32/1/217", Consumo_Elettrico_Dx)
grp.write("32/1/218", Consumo_Elettrico_Sx) |
