Event Script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Event Script (/showthread.php?tid=5715) |
Event Script - tomnord - 01.11.2024 when using event script, we use the event.getvalue() function. Is there any way to get the grp name in event script? RE: Event Script - Daniel - 01.11.2024 https://kb.logicmachine.net/libraries/lua/#grpfindalias RE: Event Script - tomnord - 01.11.2024 But that recuires me to know the GA address, can i get that without manually entering it? Also, is there any way to copy event scripts to multiple GA? RE: Event Script - admin - 01.11.2024 event.dst contains the group address that triggered the script. Use tags to assign a single script to multiple groups. RE: Event Script - tomnord - 01.11.2024 tag based wont work with eventbased, or am i missng something? RE: Event Script - Daniel - 01.11.2024 It will, just tag your objects. Create event script with this tag. Drop this and start writing to your objects. See what happens in logs Code: log(grp.find(event.dst).name)RE: Event Script - tomnord - 01.11.2024 (01.11.2024, 09:20)admin Wrote: event.dst contains the group address that triggered the script. Use tags to assign a single script to multiple groups. (01.11.2024, 10:37)Daniel Wrote: It will, just tag your objects. Create event script with this tag. Drop this and start writing to your objects. See what happens in logs I got the event.dst to work, but I wanted to copy my event script to multiple group adresses, preferably automated copy. RE: Event Script - Daniel - 01.11.2024 Do not copy, use tag and single script for all. RE: Event Script - tomnord - 01.11.2024 (01.11.2024, 10:45)Daniel Wrote: Do not copy, use tag and single script for all. Ah, I see. As resident script then? RE: Event Script - Daniel - 01.11.2024 Can you explain in more details what are you trying to do? |
