grp.checkwrite - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: grp.checkwrite (/showthread.php?tid=5719) |
grp.checkwrite - CristianAgata - 04.11.2024 Good evening, I have a doubt, I always use checkwrite with the command feedback, here an example: stato_int = grp.getvalue('cmd_1') luce_1 = grp.getvalue('luce_1') if luce_1 == true then grp.checkwrite( 'cmd_1' , 1 ,1, stato_int) else grp.checkwrite( 'cmd_1' , 0,1 , stato_int) end And this works fine. Problem, on a plant I don't know why, some time I found the command on but status off so I tought to pass the status but it doesn't work. Where m'I wrong? stato_int = grp.getvalue('Status_cmd_1') luce_1 = grp.getvalue('luce_1') if luce_1 == true then grp.checkwrite( 'cmd_1' , 1 ,1, stato_int) else grp.checkwrite( 'cmd_1' , 0,1 , stato_int) end Best regards Cristian RE: grp.checkwrite - admin - 04.11.2024 https://forum.logicmachine.net/showthread.php?tid=4472&pid=35746&highlight=checkwrite#pid35746 RE: grp.checkwrite - CristianAgata - 04.11.2024 (04.11.2024, 15:57)admin Wrote: https://forum.logicmachine.net/showthread.php?tid=4472&pid=35746&highlight=checkwrite#pid35746 Perfert, with the group address it works.... so I don't use the variable read with the grp.getvalue(). Thanks |
