attempt to index global 'mb' (a nil value) - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: attempt to index global 'mb' (a nil value) (/showthread.php?tid=5738) |
attempt to index global 'mb' (a nil value) - Simuzer - 12.11.2024 hi all, I have a project that uses LM and Wago PLC. I am communicating with Modbus. i think so that if mb is global variable, the problem will be solved LM send a value to PLC by using event-based script this like : event for (32/1/2) Code: value = event.getvalue()
mb:writeregisters(0, value)LM get values from PLC by using resident-script : Code: require('luamodbus')
mb = luamodbus.tcp()
mb:open('192.168.1.102', 502)
mb:connect()
value = mb:readregisters(0)
grp.update('32/1/2', value)
mb:close()I have 2 questions. First; I don't want to write connect and ip in every event script. Because when the PLC IP address changes, it will be troublesome to change all of them. And this type of usage is not a correct usage. Second; If the value of LM or PLC changes, that value will be equal in both. RE: attempt to index global 'mb' (a nil value) - admin - 12.11.2024 You can't share the connection this way. You must open a new connection in each script separately. The best approach is to create a profile instead of multiple scripts. RE: attempt to index global 'mb' (a nil value) - Simuzer - 12.11.2024 it works like this. Resident Code: require('luamodbus')
PLC_IpNo1 = '192.168.1.102'
PLC_IpNo2 = '192.168.1.103'
mb:open(PLC_IpNo1, 502)
mb:connect()
storage.set('strPLC_IpNo1', PLC_IpNo1)
storage.set('strPLC_IpNo2', PLC_IpNo2)
curr = mb:readregisters(0)
prev = storage.get('prev_value')
if curr ~= prev then
storage.set('prev_value', curr)
grp.update('32/1/2', curr)
mb:close()event-based. Code: PLC_IpNo = storage.get('strPLC_IpNo1')
mb:open(PLC_IpNo, 502)
mb:connect()
mb:close() |
